Results 1 to 10 of 12
Thread: pool got cloudy after adding pH UP
    Jun 2014
    Ontario
    Default pool got cloudy after adding pH UP
    Hello and thank you for reading this.
    Yesterday my pool was crystal clear. I checked the water and I was low on pH (7 - 7.2) as well as low on chlorine.
    Before adding any chlorine I wanted to get my pH just right. I added just under the recommend amount directly into the skimmer.
    An hour later my pool was cloudy and still is.
    Any ideas?
    Default Re: pool got cloudy after adding pH UP
    Some questions for you:
    --Do you have a drops-based test kit? Can you post some current water testing results?
    --How much pH UP did you add?
    --What kind of pool is this and what is the volume?
    --What size of pump do you have?
    --What kind and size of filter do you have?
    --Exactly what all have you added to the pool -- meaning ingredients and not just product names like 'shock.'
    Re-post with the requested info and someone here will try and help you.
    Welcome to the Pool Forum!
    Almost certainly, you have high-ish calcium and ended up precipitating calcium carbonate particles. So . . .
    1. Use borax to raise your pH, and avoid the problem.
    2. Get a K2006 so you can manage your pH/alkalinity/calcium levels properly. http://pool9.net/tk/
    3. If your calcium is high because someone told you to add calcium, but you have an FG or vinyl pool, STOP adding calcium. There's no need for it. http://pool9.net/calcium/
    . . . membership updated.
    Jun 2014
    Ontario
    Thanks for updating!
    1. Will do! Thanks for the tip. Are their guidelines on how much Borax to add? Is adding Borax to a hot tub OK as well? I just add backing soda to my hot tub until the pH is about right.
    2. I live in Canada, so I have to use Amazon.ca, and those products are not available through that vendor... Too bad.
    3. I have never added calcium to our water, but we do have high calcium (hard water with lots of iron).
    I forgot to add:
    So now that we believe it's a high calcium content: what can I do about it?
    I was thinking about adding the clarifier to the filter like they recommend in the instructions (30mL to 50mL / 10,000 Litres). Says "may be added directly to the skimmer in the evening. The pool filter should be backwashed the next morning".
    + Start off with 1/2 box per 10k gallons (~40k L) for large pH changes (7.0 => 7.6); 1/4 box for small (7.0 => 7.2)
    + Check the page again; I believe I link to a French Canadian site that is selling them.
    + Don't worry about the calcium, till you have the kit. In any case, it won't be an issue if (a) you don't have a heater and (b) you don't add any more.
    Jun 2014
    Ontario
    Well, I don't have a pool heater, but I may get one. If I do, I'll make sure to do proper water treatment.
    How do I get rid of the cloudiness, though? By filtration? Or is there a chemical approach (other than flocking)?
