Thanks for updating!
1. Will do! Thanks for the tip. Are their guidelines on how much Borax to add? Is adding Borax to a hot tub OK as well? I just add backing soda to my hot tub until the pH is about right.
2. I live in Canada, so I have to use Amazon.ca, and those products are not available through that vendor... Too bad.
3. I have never added calcium to our water, but we do have high calcium (hard water with lots of iron).
I forgot to add:
So now that we believe it's a high calcium content: what can I do about it?
I was thinking about adding the clarifier to the filter like they recommend in the instructions (30mL to 50mL / 10,000 Litres). Says "may be added directly to the skimmer in the evening. The pool filter should be backwashed the next morning".
