Salt Water Chorine Generation is fine. I'd run fast away from anything "mineral", "ion", "ozone", "UV", "Eco", or "Low Chlorine".
Thank you!!!!!
If you buy a Hayward / Goldline salt unit, follow the directions here, and add borates to the water . . . you WILL have a "Mineral Springs" system at about 1/3 the cost.
Hayward puts labels on the Mineral Springs hardware for Bioguard. The chemicals used are just pre-blended (so if you have too much of one, you're stuck) and over-priced salt + borax + acid + stabilizer, in different packages and ratios.
Thanks PoolDoc, I had no idea that Mineral Springs was a luxury marque. It sounds like a collection of metal salts, at least to me.
Yeah. They try hint at the idea that it's a 'natural' 'non-chlorine' system without actually making illegal claims to that effect.
