Thread: New motor or new pump?
    May 2014
    Florida
    Default Re: New motor or new pump?
    Hi Tom - If it were me I would go with the B2982T dual speed replacement motor which comes with a digital timer, this motor can be found for $335 you would also need a 5250-106 seal which is about $15 this is a 1 HP full rate motor which would be identical to your 1.5 HP up rate motor. The B2982T has a digital timer right on top of the motor for easy programming. There typically is really no need to replace the pump housing and replacing the motor would be fine.
    Inyopools
    Mar 2014
    NC
    @TomB --- you really don't need to run your pump 24/7. It will save you quite a bit of $$$ on power bills if you don't. 8-10 hours per day would be more than plenty.
    Yes... I know that NOOOWWWWW ;-) ... But I didn't know it when I was spending many thousands at the pool store every season. You keep forgetting what an idiot I was prior to finding this forum :-D I think I have the timer set to run it 10-11 hours a day (in two cycles) now.
    25,750 ga 18x36 Rectangle IG Vinyl liner; Hayward 250 sand filter; 1.5 hp pump. PF=4.4
    TomC is offline PF Supporter Thread Analyst TomC 0
    New York
    Thanks for all the replies. I was able to find the entire pool pump online for $559, no tax, free shipping. I got it in about 2 days. Even though I had no filtration for about 5 days my pool stayed clear. I just ran my aquabot about 6 hours a day and my pool stayed nice and clean. I had to hand skim it though, no biggie, that's why I have sons
    So the direct replacement for my whisperflo WFDS-26 pump was.....the same exact model. So I disconnected the old pump, rewired and connected the plumbing to the new pump and I was in business.
    Yesterday, I took apart my old motor apart to find that the bearings were seized, maybe just one, but maybe both. I couldn't remove them. We have a guy here in town that fixes and rebuilds motors, he did my brother's pool motor 2 or 3 years ago. I'm going to bring it to him today, he said on the phone it may take him a week until he gets to it, and that the 2 bearings, motor shaft seal, should be less than a hundred bucks. I figure I'll keep it as a spare, or as an auxiliary pump should I ever get around to adding that waterfall my wife wants.
    Tom
    20'x42' L' 41K gal IG vinyl pool; trichlor feeder, bleach; Pentair 420 cartridge filter; Pentair Whisperflo 1.5hp 2 speed pump; hrs; TF-100, CYA test; city;PF:2.9
