Page 4 of 4 FirstFirst ... 2 3 4
Results 31 to 34 of 34
Thread: Need help...still cloudy after more than a week...very hard water
  1. #31
    Jun 2014
    Colorado
    Default Re: Need help...still cloudy after more than a week...very hard water
    Happy 4th of July!! My pool is finally beautiful, sparkling clear and perfect temp! I am working on balancing the FC and CYA and getting into a routine of testing. Once it is stabilized, how often do I check the CYA, PH, CH? Daily for the FC, right? I'm SO excited to have my pool back without all the gunk. THANKS!
    8k gal 16x24 oval AG pool; mesh winter cover, well water fill, Premium Blue 22 sand filter, Premium Blue 1.5hp 1spd pump operating 24/7. PF=15
  2. #32
    Unless you do some thing to add CH, you don't need to check it: it won't change unless water is removed from the pool.
    Until your TA is in a more normal range, you might want to check it every couple of weeks.
    CYA, again, won't change unless you do something to change it. So if you drain a lot of water, backwash a lot, or are using stabilized chlorine, you might need to test it occasionally.
    pH & chlorine? Check it with the K2006 every few days; use a cheapo OTO / phenol red kit to check it daily.
    With more experience, you can extend your test intervals.
  3. #33
    I'm really happy to hear that your pool is clear!! Congrats! Now it is time to enjoy it!
  4. #34
    Jun 2014
    Colorado
    Cool Re: Need help...still cloudy after more than a week...very hard water
    The overview of the testing routine is very helpful. I am confident that my pool will continue to look great so we CAN enjoy it, instead of being a pain all summer. This forum has saved me much time and money. Thank you again! Happy summer!
  1. Cloudy ,Cloudy,Cloudy... for a week now.
    By uwinsome in forum Dealing with Algae & Slime
    Last Post: 07-14-2011, 06:55 PM
  2. Pool still cloudy white. Been a week today... This stinks.
    By Lawrosa in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-14-2011, 12:13 PM
  3. Blue-Green water for over a week
    By poolboyforjenny in forum Dealing with Algae & Slime
    Last Post: 05-24-2008, 11:42 PM
  4. Clear->cloudy->green in a week, alkalinity problem?
    By PoolInMich in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 08-06-2006, 09:25 PM
