Thread: Received PS234 kit today and here are numbers
    KPROMERO is offline Registered+ Thread Analyst KPROMERO 0
    Broussard, Louisiana
    Default Received PS234 kit today and here are numbers
    FC = 12.5 Lowered dial down on SWG ( now at 20 was on 40)
    CC = .5
    TC = 13
    PH = 7.2 Trying to lower TA
    TA = 140
    CAL = 200
    CYA = Was below 100 line ( about an 1/8 of an inch)
    Salt = 3200
    Temp = 88
    What do you all think I should do since I am new to this. And thanks Ben for sending the kit
    Default Re: Received PS234 kit today and here are numbers
    I'd grab a cold one and go swimming!
    Seriously, I don't think I'd worry about the TA being 20ppm too high. Chances are with the SWG/SWC the PH will climb back up anyway. Keep your FC up since your CYA is so high and enjoy!
    Thanks for info. I was at 180 for TA and thats why I lowered ph from what I read in forums to do.
    With a SWG and the CYA near 100 you should probably run your FC at around 3-5 ppm. If you are not getting CC with this setting it's working.
