How about this?
Since you have pucks, no CYA, and a high pH why not take advantage of the inline chlorinator while you are away for the weekend?
This will allow you to keep the CL level up over the weekend and will bring your pH down a bit due to the acidity of the pucks.
The only negative I can imagine would only be if the pucks contained copper. If so I wouldn't use them.
