Results 11 to 13 of 13
Thread: High reading for CC after shock treatment
    Default Re: High reading for CC after shock treatment
    When you fill to the bottom mark on the tester, that is 10mL and you need to use the 0.5 multiplier.
    Still don’t understand why CC was so high. As mentioned, the spa has only been used by myself and always after a shower, also for only about 5 minutes at a time. Chlorine has always been kept at a min. of 3. Could it be that after shocking it that there was so much gunge in it that it was converted into lots of chloramines? If that was the case, how could it have got there? Strange that the water was so clear & sparkling.
    There are 3 possibilities that I can think of:
    1) People goo
    2) Possibly in the past, you added some sort of pool chemical that reacts badly with chlorine
    3) Some sort of testing error occurred.
  1. High CYA, so keep FC high, so are my high PH readings, falsely reading high ?
    By tdurban in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 08-19-2013, 11:46 AM
  2. green water with high chlorine reading
    By grammy57 in forum Pool Chemistry for Intex-type Pools
    Last Post: 07-17-2013, 11:47 PM
  3. Still no CYA reading - low Ph - high Alk - how to proceed?
    By Stacyf419 in forum Pool Chemistry for Intex-type Pools
    Last Post: 06-18-2012, 05:06 PM
  4. high CYA and phosphate reading
    By vivian in forum Dealing with Algae & Slime
    Last Post: 08-05-2006, 11:44 PM
  5. Water turned green after adding shock treatment
    By NowhereMan in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-11-2006, 12:25 PM
