Re: Phosphate testing
CarlD
Seriously, I'm wondering what the original poster thinks reducing phosphates will do to reduce chlorine usage. If you don't have algae in your pool, reducing phosphate levels should have little effect on the chlorine levels. Phosphates are algae food...but if there's no algae, there's nothing to feed.
I just don't see the mechanism.
I agree with you. It's not the amount of bleach used so much as the maintained level I was originally thinking of reducing. Right now and forever I'm going to have to keep my FC level at the higher end (relative to CYA) to keep the algae at bay. That's ok by me. I just wanted to explore other options. This thread is proof positive of the BBB method works best.
19.5k gal, 16x32 vinyl liner, sand filter, 1hp single speed pump, K-2006 test kit. PF=6
