Results 1 to 10 of 32
Thread: Phosphate testing
    Jun 2014
    Default Re: Phosphate testing
    I can see the algae in my pool tends to cling along the seams of the liner in deep end. That makes it tough to brush it off. It's never gonna go away completely. So containment is the key.
    Really I'm just looking to dial in what's best for my pool. Whatever it takes to keep it clean, sparkling, and open all through this my 1st season is ok by me.
    Thx
    19.5k gal, 16x32 vinyl liner, sand filter, 1hp single speed pump, K-2006 test kit. PF=6
    Actually, you can kill it. Monochloramine* (chlorine + ammonia + high-ish pH) will kill it. But it's such nasty stuff . . . and pools prone to algae tend to have it come back even when you do kill it.
    Copper will also kill it. But then you get stains and green hair. (I've actually DELIBERATELY stained pools that had very rough porous plaster.)
    Super high chlorine will kill it.
    But . . . it appears that moderate levels of chlorine will kill it when phosphate levels are very low. So that's what I'm experimenting with, now.
    * Products like Yellow Out and Mustard Master work this way.
    Virginia
    So what's the current thinking on using phosphate removers?
    I use to use one at the end of every season, but last year I stopped doing it since it seemed the message here was that they are a waste of money.
    Now I see more discussion about possible benefits of removing phosphates. I'm sure my pool has phosphates since I add 6 oz of Jack's Magic Purple stuff each week to keep stains from appearing on the steps (interestingly, the bucket metals test recommended here was negative for any metals).
    So, should I resume my annual phosphate treatment or is phosphate removal only recommended for "problem pools"?
    For reference my pools stays clear and CL holds overnight. I keep FC 5-6ppm and CYA 70-80 (recommended CYA level for my SWCG).
    Right now, I'm working on the theory that you don't need PO4 removers, unless you need them, and that there are 2 groups that may need them:
    1. Those with pools prone to recurrent mustard algae, and
    2. Those taking long or repeated vacations, and who lack anyone to check on their pool every few days.
    Jun 2014
    It's interesting how this thread has morphed from testing for phosphates to testing the whole need to do so in the first place. I guess the answer (for me anyway) is it doesn't seem likely the effort is worth it. I'll just keep my FC at the upper end of the best guess chart, raise the CYA to about 60 and see how it goes.
    It has been worth the effort to discuss the idea here. Thanks for all the expert info.
    Happy 4th all
    Splash
    That's a good plan. I find the persistent algae point is inside my wedding cake stairs. Water circulation is almost non-existent there and it's impossible to get inside it to brush--but you can see inside.
    Quote Originally Posted by Big Splash View Post
    Happy 4th all
    Thanks! You, too!
    Regarding the question of whether phosphate level control is "worth it", if
    (a) you don't have problems with persistent algae in spite of good chlorine levels, and
    (b) you aren't having difficulties keeping your pool clear and clean during vacation or other absences,
    then you probably don't have a reason to fool with it.
