Results 1 to 10 of 32
Thread: Phosphate testing
    Jun 2014
    Default Re: Phosphate testing
    Thread update...
    I raised the CYA to 60 using trichlor tabs and have kept the FC at or above 10. Downside to this approach is testing the pH (without having to dilute with distilled water as I've read). While there's no visible algae growth like before, I can still see some (brownish dust) come off the steps, sides and corners as I bush the areas where my pool cleaner doesn't get to. Not surprising considering all the nasty wind swept thunderstorms rolling through NJ in the past week. These storms caused a couple major leaf cleanup jobs for me. So, I think my problem isn't removing phosphates. It's stopping them from getting in the pool in first place. I might be better buying a chainsaw Other than that, I might try adding borates.
    Thanks all,
    Splash
    19.5k gal, 16x32 vinyl liner, sand filter, 1hp single speed pump, K-2006 test kit. PF=6
    The problem with phosphate removal is that many sources can provide sufficient phosphates for algae; it takes very, very little to be enough. Managing phosphate levels is easiest on pools with DE or cartridge filters, low evaporation rates, and no leaks. The reason is that most utility water contains significant levels of phosphates. As a result phosphate remover must be added to the pool EVERY time you add fill water, unless you are filling from a well or other untreated water source.
    There are two other problems.
    1. The available tests are finicky and do not measure the levels of phosphates in incoming water, where PO4 > 1,000 ppb, well. It can be done, but requires PRECISE dilution with distilled water.
    2. The phosphate removal products on the market are disappointing in quality. Only the Orenda PR-10000 product seems to offer a decent price/performance ratio.
    That said, phosphate management seems to offer the ONLY relatively easy, side-effect free method of managing mustard algae in that fraction of pools that suffer recurring episodes.
    => Ammonia based products (Yellow Out, etc.) generate high levels of the VERY irritating monochloramine, and screw up chlorine management downstream of their use.
    => Bromide based products (Yellow Treat, etc.) are not especially effective against mustard algae, and make it impossible to stabilize the halogen (chlorine + bromine from converted bromide) residual, resulting in huge chlorine demand downstream.
    => Raising FC levels to 30 or 40% of the CYA level works, but not instantly, and can leave pools at levels that can bleach swimwear and some pool liners for days after treatment, depending on the initial CYA level
    => High levels of copper ARE effective, but they are ALSO effective at staining pools and turning hair green.
    => Borates help with other forms of algae, but apparently are only marginally effective with respect to mustard algae. However, other than cost, there is no downside to their use.
    I just realized that I have been assuming people knew what I know, and have been failing to mention PHYSICAL BRUSHING OF THE POOL IS ESSENTIAL, regardless of which mode of chemical treatments for mustard algae you follow.
    If you have mustard algae, you MUST brush!
    Jun 2014
    Got ya'
    I'll keep brushing just like Mamma said Works for your teeth and your pool.
    Thanks Ben.
