Thread: high chlorine or lower chlorine + polyquat
    Apr 2014
    SE Louisiana
    Default high chlorine or lower chlorine + polyquat
    Are either of these methods much better than the other in preventing algae or other problems?
    My CYA is around 100. Up until now I am just using bleach in the skimmer every 3-4 days to keep FC around 6-10ppm
    But just curious if running a lower chlorine (3ppm or so) and adding polyquat every week would be just as good?
    Also,even if I just run higher chlorine would it be good to supplement with polyquat as an extra preventative or would that just be a waste of money?
    16x32 in-ground rectangle | chlorine pool | vinyl liner | k-2006 test kit
    Default Re: high chlorine or lower chlorine + polyquat
    If you don't have an SWCG then you should be keeping your FC between 8 and 15 with a CYA of 100. You cannot run a lower FC level by relying on Polyquat, though it will help keep algae at bay.
    Polyquat's good at keeping algae from starting, and, if you can't keep FC up it can help.
    Apr 2014
    SE Louisiana
    great, thank you!!
