Thread: Small-- less than 1000 gallon intex question
    Jul 2014
    IN
    Default Small-- less than 1000 gallon intex question
    Hi. We have an 8 ft intex 696 gallon pop up pool. I have read the simple instructions for 2000 plus gall
    Default Re: Small-- less than 1000 gallon intex question
    Honestly, with that a pool that small, you need to use the SSR -- but drain it every 2 weeks.
    There's simply not enough water to treat it like a regular pool. Put another way, in a pool that small, the 'people goo' becomes too concentrated to deal with the same way. It's more like spa, with a really bad filtration system.
    Get a cheap OTO kit; use the chemicals found in the SSR, add a dose of chlorine every evening. But also add a small dose before, and a regular dose after each time the pool is used.
    Then, drain and refill it every 2 weeks.
