Thread: Shelf Life of CYA
    psteward is offline ** No working email address ** psteward 0
    Omaha, Nebraska
    Default Shelf Life of CYA
    Does anyone know the shelf life of CYA or if heat (90-95) hurts it?
    Default Re: Shelf Life of CYA
    CYA should have a pretty long shelf life but high heat is not good for any chemical. Try to keep it at more normal room temp.
  1. Bleach shelf life guidelines
    By steveinaz in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 04-30-2012, 12:09 PM
  2. Shelf Life of test kit reagents
    By SandyDittmer in forum DPD-FAS based testing
    Last Post: 06-24-2010, 09:22 AM
  3. polyquat shelf life
    By prh129 in forum Pool Chemicals & Pool Water Problems
    Last Post: 05-29-2007, 01:44 PM
  4. Reagent shelf life?
    By AndieP in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-03-2006, 04:04 PM
  5. Bleach Shelf Life
    By zelmo in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 04-08-2006, 08:31 PM
