Re: Debris floating on surface
The prevalent southerly winds are completely blocked by the house.
The weir is in good working order.
I don't know how to judge the skimmer flow. I only know there is plenty of suction from the skimmer to the pump.
I'm going to play around with the jets and see if I can make them push the debris toward the skimmer.
Thank you both for your replies.
IG pool
