Results 1 to 10 of 17
Thread: Skimmer not catching debris floating on surface
    Default Re: Debris floating on surface
    I'd take the other two and -- carefully -- use a Dremel tool, die grinder, wood rasp, or small coarse file to open the slot, till you achieve sufficient flow.
    To stabilize the work, you'll probably need to screw the jet into a 1.5" FIP adapter on a piece of 1.5" PVC pipe.
    Jun 2014
    Texas
    I have rasps. I'll make that a weekend project.
    IG pool
    Again, if you can, please post results.
    Jun 2014
    Texas
    I'll do it Doc.
    IG pool
  1. white substance floating on pools surface
    By erika1026 in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-20-2014, 04:37 PM
  2. Foamy chemical floating on surface...
    By finks213 in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-19-2013, 06:57 PM
  3. Oil slick looking surface inside skimmer
    By mneal in forum Pool Chemicals & Pool Water Problems
    Last Post: 09-28-2006, 01:02 PM
  4. Too Much floating debris overloading skimmer.
    By jenpen400 in forum Pool Cleaning: Manual or Automatic
    Last Post: 08-26-2006, 07:42 PM
