Results 11 to 17 of 17
Thread: Figuring Flow Rate
    Jun 2013
    Central Florida
    Default Re: Figuring Flow Rate
    You can put a flow meter in your system. Try www.bestbuypoolsupply.com. Look under "in ground solar parts" and scroll down to the bottom of the page. About $60.00. Mark may want to comment about their accuracy.
    Oct 2013
    Rhode Island
    'rameses, I considered getting one. I might use Gary's trick, but just disconnect the return line to fill the bucket.
    Sharkline Escalade RTR 24' x 54" Round AGP; OptiFlo 2-speed pump; Pentair PLM-100 Cartridge Filter; Hayward 250FDN Heater; Taylor K-2006; AquaIlluminator Return
    mas985's Avatar
    Pleasanton, CA
    Any modification to the return side plumbing will have a dramatic affect on the flow rate so again, would not be very accurate.
    Mark
    Oct 2013
    Rhode Island
    Okay, I'll drop that idea. I suppose the resistance of the return fitting would change the flow rate.
    Oct 2013
    Rhode Island
    Quote Originally Posted by mas985 View Post
    If you want more than guess, I would need a picture of your equipment setup and also the filter pressure on high speed.
    Mark, here are the pictures (I think… never done this before):
  6. #16
    mas985's Avatar
    Pleasanton, CA
    I figure somewhere around 60 GPM on high speed and 30 GPM on low speed. But, adding a heater will add head loss and will reduce flow rate. If I add the head loss of a typical heater, it would drop the flow rate down to about 56 GPM on high and 28 GPM on low. So it should still be ok but it will depend on the heater head loss which isn't always published.
    Mark
  7. #17
    Oct 2013
    Rhode Island
    Thanks Mark. I just read a little more of the installation manual. Nothing there about head loss, but the heater is adjustable for pressure, so I'm hoping I'll be OK. Also I noticed there is a paragraph about two-speed pumps:
    "TWO-SPEED PUMP:
    In a few cases the pressure from a two-speed pump is below the 1- pound minimum required to operate the water pressure switch on the heater. This is apparent when the pressure switch cannot be further adjusted. In these cases the pump must be run at high speed to operate the heater. If the pump and piping arrangement are such that the required 1-pound minimum pressure cannot be obtained, do not attempt to operate the heater. Correct the installation."
    I assume by "pound" they mean "PSI" so given that I am at 4 psi on low, I should be OK I guess.
    Thank you again to all for your help! Pool Forum is a great resource!
  1. Flow rate sensor?
    By henryb in forum Pool Electronics
    Last Post: 08-31-2013, 03:51 PM
  2. Pump mismatch with skimmer Flow Rate
    By jtran69 in forum Pool Equipment & Operations
    Last Post: 04-23-2013, 12:34 PM
  3. PVC Maximum Flow Rate?
    By catnip in forum Pool Equipment & Operations
    Last Post: 03-14-2007, 01:15 PM
  4. Design flow rate vs maximum flow rate...
    By cruzmisl in forum Pool Equipment & Operations
    Last Post: 06-27-2006, 07:50 AM
  5. Two-speed pump flow rate
    By sharkey21 in forum Pool Equipment & Operations
    Last Post: 05-03-2006, 09:18 PM
