Closed Thread
Results 1 to 10 of 12
Thread: Electrical for pool
    Default Re: Electrical for pool
    To answer your innitial question, no, you do not need to run a second line from the house, the sub panel, if installed off the main panel correctly will allow you to hook up as many breakers/individual circuits as it will accomodate.
    thanks for all the input. Any body have pictures of their subpanel setup. thanks chris
    Blding 18x36 IG vinyl rectangle with custom inpool steps, 22,000 gallons. Chris In Chapel Hill, NC [email protected]
    Here is the panel I used. http://www.intermatic.com/?action=prod&pid=8849 The 2 timers are for the pool sweep and the main pump. The panel excepts breakers right inside and I also have a GFI breaker in there that runs a convenience outlet (weatherproof cover) located in a small box directly under the Intermatic panel.
    Thanks for the info Mark. Who did you purchase the intermatic through? how much power do you have running to the panel?
Closed Thread
