How do I find my pool chart? I also need to edit since I should have 2 pool charts. first one is from previous home.
17k gal 16' x 32' IG concrete bottom FG sides 1985 , Hayward Pro S244T sand filter , Hayward Super pump 1 HP 12 - 24 hrs , using 8.25% bleach, K-2006C kit. PF=7
The *form* is here: http://pool9.net/pf-equip-form/
The results are not accessible, because they include registrant's email addresses. But if you'll enter new form results, I'll update your signature for you.
Do you have 2 pools? Or, do you need to replace old records with new ones?
I just filled out a new pool chart a week or two ago. I wanted to delete the old one. It was a. AG pool, the newer one is for my IG pool I have now. Do I need to fill out another one?
You'll note that I edited your signature to reflect your most recent entry. I recalculated your volume, assuming a transition from shallow to deeper beginning at the mid point.
I didn't find your earlier entry; it may be in the 2012 or 2013 lists.
Thank You ! I believe the earlier entry would be in the 2012 list. I have switched to using mostly bleach as I have my cya level around 55-60 ppm.
OK, then that data is just sitting there, not affecting anything.
