Results 1 to 9 of 9
Thread: ANYONE TRIED A POOLVERGUNEN sp?
    May 2013
    Concord,ca
    Default ANYONE TRIED A POOLVERGUNEN sp?
    My mx 8 went out again and I was considering the Poolvernguen for my fiberglass pool. Looking for fewer parts. Thanks for chiming in. Dave G.
    13000 gallon fiberglass, variable speed pump, cartridge filter, chlorine sanitized ,k-2006, also daily 5 item check ( ch, ph,ta,)
    I only trust the k-2006 titration is better for me
    Default Re: ANYONE TRIED A POOLVERGUNEN sp?
    May 2012
    Orlando, FL
    I have one. Had it for almost two years now but its broken again (the 2 second time now). There are there plastic flappers that keep falling/breaking off. I left off one row, now there is something broken internally. A plastic piece that is blocking the suction opening.
    I'm replacing it with a "Great White". I had one before and it worked fine for about two years too. I leave my cleaner in the pool all the time so that may be contributing to the short life (you're supposed to remove them from the water when not in use).
    Anyways the GW cleaner is a lot cheaper and I know it works as good, so I'm switching back.
    mas985's Avatar
    Pleasanton, CA
    If you have a high main drain, you need to use the tires with the larger bump on them and that will prevent the cleaner from hanging up on the cover breaking the skirt. Did you ever try calling them about it? They are usually pretty responsive although now that Hayward owns them, it might have changed.
    I have had the suction cleaner for going on 9 years without incident and I think it is a pretty good cleaner. BTW, I leave mine in my pool all the time too but it doesn't seem to have shortened the life much.
    Mark
    May 2013
    Concord,ca
    anyone know why they keep pushing the 4 wheel version beside price?
