Results 1 to 9 of 9
Thread: ANYONE TRIED A POOLVERGUNEN sp?
    mas985's Avatar
    Pleasanton, CA
    Default Re: ANYONE TRIED A POOLVERGUNEN sp?
    It has a longer hose for a bigger pool and the motion pattern is also for a bigger pool.
    An easy way to determine if you need a 2 Wheel Suction PoolCleaner or a 4 Wheel Suction PoolCleaner is to imagine a 40 ft long pool. If the suction port or skimmer is half way (most newer pools) approx 20 ft from one end, then the 2 Wheel Model will be sufficient.
    If however the suction port is all the way at one end AND you have a very deepend the 4 Wheel PoolCleaner would be better suited for your pool. The best way to describe it is that the 4 Wheel model can drag more hose.
    Mark
    Interesting! Wonder how it compares to a robotic? (excepting, of course, that a robotic brushes, and acts as a filter for the water as well.)
    I'm not sure they push the 4-wheel version. Before I bought mine, we called them and they told me to go with the 2-wheel one for my pool.
