Page 4 of 6 FirstFirst ... 2 3 4 5 6 LastLast
Results 31 to 40 of 51
Thread: Low ph and algae
  1. #31
    Default Re: Low ph and algae
    Good deal.
  2. #32
    Jul 2014
    MI
    My kit is in. A few green spots yesterday. I brushed and vacuumed yesterday. Chlorine look 6 with old kit. I'm ready to rid this algae forever. Please help.
    14k gal AG pool, 150 sq ft cart filter. PF=8
  3. #33
    Watch the videos, run the tests, and report the results . . . and we'll see how we can help.
  4. #34
    Jul 2014
    MI
    I didn't get videos. I followed the box instructions. These are what I have:
    Chlorine. 4.8ppm
    No com chlorine it stayed clear
    Ph 7.2
    Alk. 350
    Cya 75 ppm
    I hope these results help.
    Christina
  5. #35
    Here is a link to the videos:> http://pool9.net/K2006-vid/
  6. #36
    CH level?
    With algae, and a CYA level of 70+, you need to maintain FC levels of 15 - 20 ppm. If you have mustard algae, even higher levels are required.
    Watch the videos, and redo any tests you overlooked or might have done incorrectly: FC, CC, pH, TA, CH & CYA.
  7. #37
    Jul 2014
    MI
    I watched the videos. Thanks that was help. I redid test.
    Cl 5.6 ppm
    Com cl 0 stayed clear
    Ph 7.3
    Alk 100
    Hardness ca. 125
    Cya 75
    I have 3 gallons of bleach here and 2 boxes borax and 1 box baking soda
  8. #38
    Good!
    Then you just need to adjust your chlorine upward, hold it there, and brush regularly.
    Normally, your chlorine level should be 10% of your CYA level (7 ppm). When you are dealing with algae, you'll need to go to 20% (15 ppm) or higher and HOLD it there, till the algae is gone.
    Physically brushing the pool surfaces, to break up the self-protective layer of slime that algae colonies produce, is VERY important. Chlorine does NOT penetrate slime well. Some other algaecides (monochloramine, copper) penetrate much better, but at the cost of some serious side-effects.
    A gallon of 8% bleach contains the equivalent of about 0.7 lbs of chlorine gas (100% available chlorine). Your PF is 8, so each gallon will add a little less than 6 ppm of chlorine (0.7 x 8 = 5.6) to your pool.
    Most dichlor is 61% available chlorine, so a pound of dichlor would add about 5 ppm (0.61 x 8 = 4.9) of chlorine and about 4.5 ppm of CYA to your pool.
  9. #39
    Jul 2014
    MI
    How much bleach would you suggest? How long do I keep it that high? Just till it's dead or much longer? Should I stay with bleach after this or go back to my unopened tab? Sorry for the questions never had this before and don't want it again.
  10. #40
    Jul 2014
    MI
    Which works quicker in killing this the 6 gallons of bleach or 5.5 tabs? Of course with me brushing and cleaning
  1. Avoiding Algae / Removing Algae
    By PoolDoc in forum Dealing with Algae & Slime
    Last Post: 07-24-2011, 10:40 PM
  2. Cloudy water...then very small amount of algae...then algae bloom
    By Allan in forum Dealing with Algae & Slime
    Last Post: 07-12-2011, 10:49 PM
  3. Wanted: Mustard algae or suspected mustard algae
    Last Post: 08-30-2007, 09:40 PM
  4. Green algae? Mustard algae?
