Re: New Intex above ground owner - Psuedomonas?
Thank you. I will test PH again. I edited to add that "I did not do the Acid or Base demand test for PH, should I have?"
And "Should I work on getting my CYA a little higher? I'm guessing I should raise my PH a little. If my CC IS 1, do I need to do something about that? and I'm guessing my FC level is good, if not too high, should I leave the bleach alone for a while or continue adding in case I do have mustard algae or the Psuedomonas stuff?"
Yep, I've been shocking with the Dichlor I already had on hand (AquaChem), though I have not added anymore Dichlor since starting with the bleach. And using 3" Trichlor tablets in a floater(same brand as the shock). I still use those.
THANKS SO MUCH AGAIN! :-)
11k gal 22' x 52" Intex Ultra. PF=10
