Thread: Dirty water
    Jul 2014
    Louisiana
    Default Dirty water
    We set up our new saltwater pump pool and when it was filled the water was clear then turned dirty looking without anyone ever being in it. We followed all the charts for its size but still looks the same and we do not have well water, what are we doing wrong help please.
    Default Re: Dirty water
    1. What kind of pool do you have?
    2. What color is your water? Is it cloudy, too?
    3. What are your pH and chlorine readings? (Go get a cheapo OTO / phenol red drops kit, if you don't have one.)
    Meanwhile:
    1. Run your pump 24/7. If you have an Intex or Summer Escapes pool, order the appropriate Unicel cartridges (see http://pool9.net/ssr/
    2. Maintain adequate chlorine levels -- use bleach or dichlor as needed. You do NOT want a pool that is dirty + algae filled.
    Jul 2014
    Louisiana
    Default Re: Green water
    It went from a dirty color to olive green its an intex pool and we have been running the pump
    Better add bleach, till the green goes away. You are about to end up with a swamp, and it takes weeks to clear a swamp in a soft-side pool, unless you have add-on filtration.
  1. dirty water
    By olddodgefan in forum Pool Cleaning: Manual or Automatic
    Last Post: 07-29-2013, 03:43 PM
  2. dirty water
    By olddodgefan in forum In-Ground Pool Construction and Repair
    Last Post: 07-29-2013, 03:10 PM
  3. dirty water
    By slack20 in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-15-2012, 03:36 PM
  4. dirty water from pump????
    By minermom in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-13-2007, 01:08 PM
  5. Jets return dirty water when I vaccum
    By JenniferB in forum Pool Equipment & Operations
    Last Post: 06-12-2006, 01:02 PM
