Closed Thread
Thread: Pool Surface Color
    Default Re: Pool Surface Color
    We've had medium gray plaster for 2 years and are very happy with it. It does have mottling that we think adds to the natural look of our pool. It's made by adding black mable dust so it's not supposed to fade like the ones colored with dye. Colored quartz can also be added which is not supposed to fade and provides a wider range of colors. I suggest asking the contractor to see some real pools (new and a few years old) since everyone has different tastes. You can also step up to the pebble and other high end finishes.
    The grey is also supposed to make your water look bluer. If you get the quartz in it, like Ultra-Poz, 3M, and Diamondbrite, it will last longer than regular plaster. They add in things to make it less suseptible to damage from the chemicals. Plus, they have different colors to make your water different shades.
    Remember in Return of the Jedi, the creature whose mouth looks like the bottom of a volcano crater? Why not have your pool bottom painted like that--SCARE the kids into staying out? ....
Closed Thread
  1. Color Splash / Color Logic Replacement LED Ligths
    By shutitdown in forum Pool Equipment & Operations
    Last Post: 06-22-2012, 01:59 AM
  2. Clear skin like substance on pool surface.
    By freddyttt in forum Dealing with Algae & Slime
    Last Post: 05-30-2008, 09:37 PM
  3. White (cloud like) marks on pool surface
    By CarlB in forum In-Ground Pool Construction and Repair
    Last Post: 07-12-2006, 12:58 PM
  4. 2 Jandy Color Pool Lights/1 Color Spa Light not synced
    By dc in forum Pool Equipment & Operations
    Last Post: 07-01-2006, 05:36 PM
  5. 2 Jandy Color Pool Lights/1 Color Spa Light
    By dc in forum In-Ground Pool Construction and Repair
    Last Post: 06-29-2006, 12:19 AM
