Results 11 to 16 of 16
Thread: Intex Ultra Frame 18 x 48 Pool
    Jul 2014
    East Texas
    Default Re: Intex Ultra Frame 18 x 48 Pool
    According to that chart I think it would be between 6 & 9 best I can remember. I check it this afternoon before coming to work. It was pretty close to the 5 may have been a little darker than the 5. Any advice on what I should do tonight.
    18' x 48 Intex
    I think you are fine tonight.
    Jul 2014
    East Texas
    Ok it's been 6 days since initial fill. I started the SWCG yesterday. I took samples before it started for today. Here are my readings:
    Cl 1-2
    pH 8.8
    Alk 140
    Hard 40
    CYA Black dot not disappearing with full tube.
    Any advice on how to proceed.
    18' x 48 Intex
    You need to check your SWCG manual and see what the requirement is for the CYA and raise it to that level for your unit to function properly.
    Your pH is way too high. Use some muriatic acid to lower it some. Please read this first:> http://pool9.net/muriatic/
    Jul 2014
    East Texas
    A dose of dichlor would help CYA correct ?
    18' x 48 Intex
  6. #16
    Yes. For every 10ppm of chlorine that dichlor adds, it also increases the CYA by about 9ppm.
  1. Intex 16x48 Ultra Frame Pool
    By bdearen in forum Pool Chemistry for Intex-type Pools
    Last Post: 06-30-2014, 04:27 PM
  2. Intex 14x48 Ultra Frame Pool
    By Blmcmillian89 in forum Pool Chemistry for Intex-type Pools
    Last Post: 06-04-2013, 01:43 AM
  3. Intex Ultra Frame Pool Hard Plumbing
    By labmom56 in forum Intex-type Pool Setup & Operations
    Last Post: 05-08-2012, 01:34 AM
  4. Who has an Intex Ultra Frame 24' pool?
    By jkoch in forum Above-Ground Pool Construction & Repair
    Last Post: 06-27-2010, 11:54 PM
