Results 1 to 10 of 23
Thread: Noob from OKC taking on liner install
    Jul 2014
    Oklahoma
    Default Re: Noob from OKC taking on liner install
    I rented a cement saw from home Depot and cut a couple 1 1/2 foot strips out of the concrete directly over the returns. Let's just say Tim the tool man would love this tool. .... Very cool. Started digging down to the return and didn't finish last night. There are many roots from nearby bushes. I still can't see how the fitting is stabilized. So far all I can see is PVC.
    Diamond blade concrete saws are SO much better than those nasty carborundum blade saws I used in the 80's: incredibly noisy, incredibly dusty, & incredibly slow. I have a little 4" diamond circular wet saw I use occasionally.
    Jul 2014
    Oklahoma
    Dug down to both of the returns and removed them. A sharp chisel made quick work of the dirt and roots. I'm going to run the returns outside of the cement about 1 ft underground. I guess I should use PVC.
    Jul 2014
    Oklahoma
    Installed the new return lines. I probably should have installed a new skimmer as well. Liner is supposed to be in this week. I ordered and have a pool trowel to help me work on the bottom of the pool.
    Jul 2014
    Oklahoma
    Pictures of my little rig for testing for leaks and some of the new plumbing. ......(sending)
    Jul 2014
    Oklahoma
    K2006 on order. Stockpiling some bleach and borax in progress.
    Jul 2014
    Oklahoma
    I had some washout around a couple of the wall panels. Had to take the panels down and reinstall. Skim coated the entire bottom with Vermiculite/Concrete mix. I did ok. Not perfect but acceptable.
    I used pennies to help hold the liner in place while installing. Unfortunately the liner is not the right dimensions. One of the sides is 16 inches too long. There are arrows in each corner.
    My pool is a fairly standard hopper as far as the perimeter goes. 16 x 32. One of the longs sides is appr. 33' 4".
    Sending some pictures.
    16' x 32' IG, 22K, 1HP sand filter
