Results 1 to 10 of 22
Thread: Should I raise my cya?
    Jun 2014
    Phoenix AZ
    Default Re: Should I raise my cya?
    So, I'm assuming you have been using some cal-hypo to chlorinate with at some point since yout CH is so high in the pool compared to your tap water. No more cal hypo!
    I'm not sure. I was using tricolor tabs before I switched to liquid chlorine about 6 months ago. I've used a couple of different products before to shock the water, so maybe there was something in those. Anyway, now I'm just using the liquid chlorine, so that won't be a factor. Thanks!
    22k gal Pebble Tec. PF=5
    Aug 2012
    Gilbert, AZ
    I'm in Gilbert, AZ so I'm familiar with the sun eating up chlorine pretty rapidly. My CYA is around 50-60 right now, I left for California last Wednesday and put 4 gallons of 10% liquid chlorine in on that Tuesday evening, today when I tested I was at 1ppm Cl. We also has a big dust storm while I was away but I came home to a crystal clear pool. I always store my liquid chlorine or bleach inside where it's cooler (78 degrees). I buy 4 gallons at a time and they last me about 2 weeks.
    Oh and I'm also having to add muriatic acid ever so often but my fill water has very high pH, so you have to figure that into everything as well.
    Where are you buying your liquid chlorine?
    PebbleTec | 25k Gallons | Purex Triton Whisperflo pump | Magnetek Century Centurion 1.5HP | Hayward Pro Series S311SX Sand Filter | Taylor K-2006 kit
    Jun 2014
    Phoenix AZ
    Quote Originally Posted by dubbedout View Post
    Wow, you burned through that chlorine pretty fast. I seem to go through about 3.5 ppm of chlorine a day on a sunny summer day, which seems pretty high to me. I'm wondering if raising my cya to 60 would slow the FC usage without messing up the chemical balance of the pool. By the way, what is your TA?
    I've been getting my chlorine mostly at Albertson's. I'll have to look to see if they are printing a manufacture date on the box. I didn't realize that it loses effectiveness in heat.
    Aug 2012
    Gilbert, AZ
    Yeah, I go through about a gallon a day I guess. I've called around to all of the local pool stores in the east valley for liquid chlorine prices and the cheapest right now is at NPS Pool & Spa Supply, 2 gallons of 10% for $4.95 (sale going on till end of July).
    Here's a breakdown of price per oz that I made up:
    Keep in mind that bleach at Sams or Walmart is likely to be fresher, and cooler, than bleach at a pool store. Take a look at their tank -- if its black poly, in the Arizona sun, it's VERY unlikely that it arrives at your pool at the rated strength.
    Another test is to 'take the temperature' of the bleach just after buying it. If it's above 90 degrees, it may be 4% bleach.
    But the best test -- if you have a K2006 -- is to dose the pool with equal doses of the various bleaches, in the late PM and test the pool FC level just before, and an hour after, dosing.
    Aug 2012
    Gilbert, AZ
    Yeah, I understand that most of the bleach/LC is trucked in and loses some strength. Most stores keep their supply indoors at least, except for one store I ran into that keeps it sitting outside in the "shade". Unfortunately, that store is the only place that sells 12.5% and you return the empty bottles and get new ones.
    I'll have to try that testing though, I've just been trying to cut down on all the waste with all the bottles and boxes which is why I switched to LC.
    Let us know what you find.
    (If you get really curious, I can tell you how to directly test bleach % -- but you'll either have to buy some accurate pipettes or a bleach kit.)
