Results 1 to 8 of 8
Thread: Brown Stain on Stairs and Liner
    Jul 2014
    Pittsburgh, PA
    Default Brown Stain on Stairs and Liner
    A few days ago, we started developing a brown stain on our vinyl stairs. We were able to clean somewhat with Mr. Clean Eraser but now stain has come back to cover stairs and has migrated to liner. A Vitamin C tablet has virtually no effect. I left a chlorine puck sitting directly on the steps overnight and can see the ring where the puck was sitting, leading me to believe it's an organic of some kind.
    I have a picture I can send but it says I cannot post attachments.
    Any ideas of what it may be or how to clean would be appreciated.
    Inground pool - 16x36, Jandy Aquapure salt generator, Jacuzzi cartridge filter, Pentair Superflow pump, Hayward heat pump
    Free Chlorine - 1.2
    pH - 7.2
    Alkalinity - 90
    TDS - 4,200
    Default Re: Brown Stain on Stairs and Liner
    1. Link to pictures hosted on Picasa, Google+, Google Drive, Flickr, Photobucket, etc using the image button
    2. Put a pile of Vit C tabs on the steps, and see if there's an effect.
    3. Was the 'stain' removed by the trichlor tab?
    4. Does the 'stain' brush away?
    5. What is your CYA (stabilizer) level?
    6. Does pouring an entire bottle of 8% bleach on the steps remove the 'stain'?
    Jul 2014
    Pittsburgh, PA
    Sorry it's taken a while to get back on this. We were on vacation and had a family issue.
    1. I'll link to picture. https://drive.google.com/?authuser=0&usp=gmail#my-drive
    2. Seems to be slight softening if we use vitamin c tablets but it doesn't just disappear.
    3. Not directly removed by trichlor tab. I'm not sure if everything around the tab got darker and the covered spot stayed the same but that's what it looks like.
    4. Some gets brushed away but some stays and won't come off.
    5. CYA 45
    6. Didn't use bleach. I used 5 lbs of trichlor shock.
    16x36 IG pool, Jandy Aquapure salt generator, Jacuzzi cartridge filter, Pentair Superflow pump, Hayward heat pump.
    + Email the picture to me -- [email protected] and include the thread number (25292) -- your link isn't an external link.
    + Try piling some Vitamin C tablets on the spot, and then put a glass on top of them, and leave them overnight.
    + Buy a small bottle of Iron Out, and cover several tablespoons of that with another glass overnight.
    Posting info from email exchange:
    Test results - 7/28/2014:
    FC:1.9; CC: 0.3; pH:7.6; TA:140; CH:100; CYA: 42; Salt:3; PO4:200.
    Water color:blue; clarity:Clear; odor:No odor; algae:No algae; feel:soft, maybe soapy
    Actions:Vacuumed pool, Added chemicals "20 oz. Knock Out Algaecide; 5 lbs. Chlor-Guard Granules"
    Equipment:
    21k gal 16x36 vinyl rectangle with both solar and safety covers; 3' - 8' depth; Jandy AquaPure SWCG; Jacuzzi 200 filter; Pentair 3/4 HP single speed pump running 24/7; Heat pump and fountain or waterfall.
    Pool is in Pittsburgh, PA area. Using Morton pool salt from Walmart.
    Pictures:
    Steps:
    Pool cleaner bag, after 24 hours of use.
    Has tried both ascorbic acid and trichlor tabs, without noticeable effect.
    BigDave's Avatar
    @PoolDoc: Are those enhanced images or directly from the camera?
  1. Brown stain on Vinyl Liner
    By fbrooks in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 05-21-2014, 01:02 PM
  2. Brown Stain
    By Tammy in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 06-03-2011, 06:22 PM
  3. If the brown stain won't brush away...
    By docsobeck in forum Dealing with Algae & Slime
    Last Post: 07-04-2010, 11:20 PM
  4. Brown stain
    By jdolby in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 05-22-2010, 07:23 AM
  5. Brown stains on stairs??
    By MaryLee in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-04-2006, 09:50 PM
