Results 1 to 8 of 8
Thread: How much water is normal to lose to light use & evaporation?
    BigDave's Avatar
    Default Re: How much water is normal to lose to light use & evaporation?
    I'm not familiar with the Triton TR-60 sand filter. Does it have a multi-port valve? If so, perhaps the spider gasket is damaged.
    Jul 2014
    Madison, WI
    Yes it does, and that was the problem. One of the "spokes" between the filter inlet and the waste outlet had slipped out of the groove it rests in, creating a small gap for water to leak out of. Glued it in place, let it dry, then greased it up. Works fine now without any leaks.
    26,000 gal IG vinyl liner pool (20'x40'), Waterway SMF-110 wet end w/ Century SQS-1072R motor, Pac-Fab Triton TR60 sand filter, K-2006A. Manually added chems: 12.5% NaClO liquid, granular CYA, baking soda, 31% muriatic acid.
    BigDave's Avatar
    Dang! You work fast.
    Congrats.
    Jul 2014
    Madison, WI
    Congrats.
    Thanks. I think I'm better at the mechanical stuff than I am with the chemicals, at least so far.
