Re: Bioguard?
PoolDoc
And if that doesn't work, the ALEX program will sell you chemicals to CREATE problems, where none existed before. The most common case, are print-outs telling pool owners to add large quantities of BOTH baking soda and calcium chloride. Doing so will turn your pool into a milk-looking mess almost instantly! We've had new forum users desperate to understand what was wrong with their pool, when the only problem was that they'd followed the ALEX printout to the letter! (And then the dealer sold them "clarifier" to help them clean up the mess ALEX had created!)
This post is an example of this where adding Balance Pak 100 and Balance Pak 200 together increased pH and TA to make the pool cloudy. Then Smart Shock was added which had copper in it that turned the cloud green.
