Thread: Cloudy Water in AG pool with DE filter
    Jul 2014
    NJ
    Default Cloudy Water in AG pool with DE filter
    Hello,
    I have an above ground pool oval 16x32.
    Recently my water tuurned cloudy. I had the water tested and was told my TC was high- 8.1ppm and my TA was low 54ppm. The PH was 7.0.
    All they recommended was a product to increase my alkalintiy. Instead i bought a 4lb box of Baking Soda and added it to the Pool.
    Two day later the pool is still cloudy.
    Any ideas
    Jul 2014
    NY
    Default Re: Cloudy Water
    Any idea what your levels are "two" days later?
    Jul 2014
    NJ
    Ok sorry i did not give you guys enough info.
    I have a DE Filter-Hayward Regenx. MY pool holds approx 15,000 gallons.
    So far I have added two 4lb boxes of Baking Soda to increase the Alkalinity. I have also shut my auto-clorinator off to reduce the TC.
    Default Re: Cloudy Water in AG pool with DE filter
    Low alkalinity is never a cause of cloudy water. High chlorine is also never a cause. So, you've gotten some pretty useless advice from your store.
    Take a look at the testkit info page: http://pool9.net/tk/ If at all possible, order a K2006.
    Meanwhile see if your local Walmart has the HTH 6-way drops kit. If they do, get it. If not, get a cheap OTO/phenol red drops kit.
    Post results, with whatever kit you find ASAP. I've got a page I wrote a number of years ago, listing 100 reasons for cloudy pool water, partly to make the point that it's very hard to tell WHY your pool is cloudy without more info. Complete test results are usually necessary, and test strips simply aren't accurate enough.
    Meanwhile, be sure to maintain adequate to high chlorine levels: LOW chlorine will result in all sorts of cloudy water.
    Also, if you haven't manually cleaned and washed your DE filter this season, now would be a good time to do so. DE filters can get choked with old DE, and that also can lead to cloudy water.
    Good luck!
  1. Cloudy water is it my filter?
    By Skymarc in forum Pool Equipment & Operations
    Last Post: 04-28-2015, 03:36 AM
  2. Cloudy water after filter change
    By JMann in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 06-20-2012, 10:53 PM
  3. cloudy water with a new sand filter
    By franky2011 in forum Pool Chemicals & Pool Water Problems
    Last Post: 08-02-2011, 03:57 PM
  4. DE filter/cloudy water
    By dsimpson in forum Pool Equipment & Operations
    Last Post: 05-17-2011, 08:56 PM
  5. Cloudy water- Cartridge Filter
    By johnnyf0614 in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-11-2009, 10:47 PM
