Thread: How do I deal with nasty surprise behind pool light?
    Virginia
    Default How do I deal with nasty surprise behind pool light?
    I noticed sometimes I will get a little algae in the crevices around the pool light (poor circulation there?). Today I decided to pull the light out to see what's behind there.
    Yuck! There was quite a bit of white-ish/off white slimy stuff and a little bit of green algae.
    I brushed everything off as good as I could and am planning on bringing CL up to shock level this evening while leaving the light out/floating.
    Does this sound like a good plan? Anything else I should do?
    I guess in the future I need to periodically remove the light and clean it out?
    Btw, I've only removed the light once before several years ago when I had to replace the bulb (I believe that was around 2007/2008).
    Advice welcome!
    Default Re: How do I deal with nasty surprise behind pool light?
    Sustained shock level should do the trick!
    Virginia
    Thanks Ben.
    How long should I sustain shock level? Just until CL holds overnight like I did for spring opening?
    Default
    What's your CYA level?
    Let me answer differently -- dose at 20 - 25 % of your CYA level, and hold it above 15% for 3 days.
    Virginia
    80
    So I'm planning to bump CL up to 20 (currently CL is at 6-7).
    Virginia
    Got it. Thanks.
  1. Pool surprise ideas wanted
    By Melissad in forum General Interest
    Last Post: 06-20-2014, 10:03 PM
  2. questions about cleaning nasty pool
    By Wheezer47 in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 03-19-2012, 05:06 PM
  3. My nasty pool deck
    By JETTA in forum Above-Ground Pool Construction & Repair
    Last Post: 07-02-2010, 04:32 PM
  4. Surprise ... Cloudy pool water
    By uwinsome in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-03-2009, 02:06 PM
