Results 1 to 10 of 14
Thread: Pump / Filter Question
    Default Re: Pump / Filter Question
    Thanks Carl, you see I am so stuck in above ground mode this time of year I completely forgot about the possibility of it being an inground pump. There is a big difference.
    howdoo, Mostly I just hook this stuff up and trouble shoot when they don't run right. If I sold them I would have to know all of this technical stuff like model numbers and what goes with what.
    I can however set up a filter system that won't leak when it is full and ready to use. 99% of the time anyway
    Maybe someone else can jump in and tell us what those model numbers mean.
    It's just Greek to me.
    Later, Dennis
    Yeah, I've been trying to find out info on it and hit snake-eyes. No luck.
    GOT IT!
    Took some sluething -- The pump is made by Poolco industries.
    Here is a link with all of the technical data, etc.:
    http://www.poolcoindustries.com/pumps.htm
    Thanks again for your assistance!
    It seems to be an above ground pool pump. I think I found info on it here.
    http://www.patiostore.com/Poolstore/...s_filters.html
    Any help?
    Dennis
    Dennis:
    I think we posted at the same time
    Check out this link:
    The spec says the pump puts out 70gpm. (I know, I know, no feet of head or anything)
    But Hayward says the S-180 T has a flow rate of 35gpm.
    Seems to me that this is 'WAY too much pump for the filter.
    But I could well be wrong.
    Yep howdoo, we got in at the same time.
    Since this is an area I am trying hard to learn I am not acting as pool pro.
    Carl, with those stats on pump and filter would I be right in saying that the water would blow right through the sand without doing much cleaning?
    All of the units I pour 200 lbs of sand into every day have either a 1 or a 1.5 HP pump attached to them. That does not seem to much different than 180lbs. Are there other variables in filter design that would establish a flow rate? And do you know, off the top of your head, how the same unit in a 1 HP would match up?
    This whole idea of matching pump to filter has really caught my attention. I always thought is was real simple. Pools were just like cars, the more HP the better.
    One more thing to consider howdoo, you may be able to find a good used filter that would match your pump. Bargains are out there.
    Tired and must sleep, Dennis
    I don't know,but the 180 uses 150#, not 180
    I have the 210--200# -- and 1hp full-rated and that's ok.
