Results 1 to 10 of 14
Thread: Pump / Filter Question
    Default Re: Pump / Filter Question
    Yeah, I've been trying to find out info on it and hit snake-eyes. No luck.
    GOT IT!
    Took some sluething -- The pump is made by Poolco industries.
    Here is a link with all of the technical data, etc.:
    http://www.poolcoindustries.com/pumps.htm
    Thanks again for your assistance!
    It seems to be an above ground pool pump. I think I found info on it here.
    http://www.patiostore.com/Poolstore/...s_filters.html
    Any help?
    Dennis
    Dennis:
    I think we posted at the same time
    Check out this link:
    The spec says the pump puts out 70gpm. (I know, I know, no feet of head or anything)
    But Hayward says the S-180 T has a flow rate of 35gpm.
    Seems to me that this is 'WAY too much pump for the filter.
    But I could well be wrong.
    Yep howdoo, we got in at the same time.
    Since this is an area I am trying hard to learn I am not acting as pool pro.
    Carl, with those stats on pump and filter would I be right in saying that the water would blow right through the sand without doing much cleaning?
    All of the units I pour 200 lbs of sand into every day have either a 1 or a 1.5 HP pump attached to them. That does not seem to much different than 180lbs. Are there other variables in filter design that would establish a flow rate? And do you know, off the top of your head, how the same unit in a 1 HP would match up?
    This whole idea of matching pump to filter has really caught my attention. I always thought is was real simple. Pools were just like cars, the more HP the better.
    One more thing to consider howdoo, you may be able to find a good used filter that would match your pump. Bargains are out there.
    Tired and must sleep, Dennis
    I don't know,but the 180 uses 150#, not 180
    I have the 210--200# -- and 1hp full-rated and that's ok.
