Thread: 1st time pool owner!!!!! Any advice??????
    Jun 2014
    Northeast Mississippi
    Default 1st time pool owner!!!!! Any advice??????
    18x28x43 true L vinyl, will be finished in about a week.
    Any suggestions for a good start up?
    Default Re: 1st time pool owner!!!!! Any advice??????
    Our Super Simple Start-up Recipe would be a great choice. It is not just for Intex pools, but for any freshly filled pool. You just adjust the doses for your volume. Read about it here:> http://pool9.net/ssr/
    Also, go ahead and order a good kit. We like the Taylor K2006 or 2006C (better buy). Not available locally but you can get it through this link:> http://pool9.net/tk/
    Welcome to the Pool Forum!
    (Until you registration is completed, you won't be able to see the rest of the forum while you are logged in. So, copy that link and then paste it into a browser window after you log out.)
    . . . membership updated.
    If you are willing to jump through a few of my hoops, I'll work with you individually to develop an exact recipe. I need to expand the SSR to cover larger pools, and yours would be ideal . . . IF:
    1a. You are filling with city water, not well water, OR
    1b. If filling with well water, you do the bucket test, and get a negative result.
    2. You have access to a Sams Club, or can get undiluted dichlor elsewhere (not: Walmart, Costco or Kmart! -- Lowes and Home Depot, maybe.)
    3. You are willing to follow instructions and NOT mix and mingle pool store advice with ours.
    Good luck!
  1. 1st time pool owner
    By BJohnston in forum General Interest
    Last Post: 07-09-2014, 03:55 PM
  2. 1st time pool owner
    By becka'sworld in forum Pool Chemistry for Intex-type Pools
    Last Post: 06-13-2013, 11:09 AM
  3. Hi! First time pool owner needs help....!
    By Anonymous [GDPR] European in Sweden in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-03-2012, 08:29 PM
  4. Need advice first time pool
    By Gofast73 in forum Pool Chemistry for Intex-type Pools
    Last Post: 06-21-2012, 10:08 PM
  5. 1st time pool owner
    By hamiltonmike in forum Above-Ground Pool Construction & Repair
    Last Post: 05-23-2010, 11:22 AM
