Re: Yea!!!!!!! The pool is up and running!
Thanks Aranon, very nice to here.
About the cloths pin. Had to laugh a little, I have done that.
If you leave the pin there it will cause problems down the road. If it pokes through on it's own because of a cleaner rubbing against it or a heavey foot coming down hard on it you will not know until some sort of damage is already done.
This is going to sound a little strange but I would not waist all of that water. I would grab that piece of vinyl you cut from the skimmer opening, cut a 1"circle out of it and get some Boxer vinyl glue. Make a very small incision and remove the pin. Apply the patch. The patch will last as long as the liner does and if you use actual pool vinyl you will never see it.
I have done this on occasion with a rock that sticks up through the sand. I go down with a rubber malet and gently tap the rock. Most of the time it sinks into the sand with no damage done. A couple of times I have had to hit the rock so hard it damaged the liner before it dissapeared. I just patched it. I still feel that is better than draing the pool. Just my opinion.
Later, Dennis
