25k gal 22 x 34 concrete free-form (oval) IG pool; city water; SWCG, Jandy CV460 cartridge, Jandy SHPF pump, 12hr, bubbler. PF=4.8
You need to maintain a chlorine level around 10% of your CYA (9 ppm), so your chlorine is way too low. You'll grow algae at your current level. But use bleach, not your SWCG to shock. Trying to 'boost' or 'shock' using an SWCG leads to greatly reduced cell life.
Your pH is too high; you need to keep it lower. But you may be dissolving pool plaster that's ALREADY softened and weakened. So, I wouldn't go too low. Maybe, 7.6 - 7.8.
BUT . . . you need to inspect your SWCG cell; the plates may need to be cleaned, given all the movement in pH, calcium and TA levels.
I've never used bleach, is there a formula for how much to use?
Today, my pH is 7.4 after adding acid last night. My alkalinity went from 110 last night to 70 this morning. Is that because I turned the bubblers off? Am I at the point now where I can control my pH by bringing up the alkalinity?Your pH is too high; you need to keep it lower. But you may be dissolving pool plaster that's ALREADY softened and weakened. So, I wouldn't go too low. Maybe, 7.6 - 7.8.
I will inspect the SWCG tomorrow.BUT . . . you need to inspect your SWCG cell; the plates may need to be cleaned, given all the movement in pH, calcium and TA levels.
Your PF is 4.8. Walmart 8% bleach, per gallon, is equivalent to 0.7 lbs of chlorine gas. So 1 gallon will add 4.8 x 0.7 ppm chlorine to your pool, or 3.4 ppm.
Likewise, if you use dichlor (61% available chlorine in some forms), 1 pound would add 4.8 x 0.61 = 2.9 ppm.
I'm not sure why your pH is moving; there are multiple possibilities. Focus on managing your chlorine, keeping your pH between 7.0 and 7.8, cleaning your SWCG. Run things for a week or two so you establish 'normal' patterns.
I am posting my pool readings for the last 11 days. As you can see pH is all over the place. I pulled the SWG and it was pretty clean but I followed the mfg. instructions and acid cleaned it anyway.The water is very clear and I don't see any dust when I brush. Come to think of it, last year when I brushed I would always see dust. That must have been when my plaster was being attacked! Also, last year is when my original Jandy SWG needed replacing. During that time my pool chemistry got out of whack as the SWG quit right before our vacation and I neglected the pool for about a week. It's all starting to make sense now. I feel like I have things under control now but it is driving me nuts chasing the pH like that. Any suggestions on the pH? Am I resigned just adding acid every other day?
As for the chlorine, I read elsewhere on your site that 4.5% of CYA is good for a SWCG pool and you are saying 10%. Why the difference?
One more thing Doc. What are your thoughts on a "No drain acid wash"? My plaster is blotchy now and I was wondering if that would help with the blotchiness and maybe smooth the plaster at the same time.
Here are my pool readings:
Date FC/ CC/ pH/ TA/ CH/ CYA
7/13 1.0./ 0.0/ 7.8/ 110/ 320/ 90/ Added 3 pts. MA
7/14 2.5/ 0.0/ 7.4/ 70/ 300/ 80/
7/15 2.5/ 0.0/ 7.6/ 100/ 300/ 80/ Added 1 pt. MA
7/16 3.5/ 0.0/ 7.8/ 100/ 300/ 80/ Added 1 pt. MA
7/17 4.6/ 0.0/ 7.8/ 80/ 300/ 75/ Rain, no acid
7/18 5.4/ 0.0/ 8.0/ 100/ 300/ -- Added 1 pt. MA
7/19 5.0/ 0.0/ 8.0/ 75/ 300/ -- Added 2 pts.MA
7/20 6.8/ 0.0/ 7.6/ 75/ 300/ --
7/22 6.5/ 0.0/ 8.0/ 100/ 275/ 80/ Added 1 pt. MA
7/23 5.8/ 0.0/ 7.8/ 75/ 275/ --
7/24 6.4/ 0.2/ 7.8/ 75/ 275/ -- Added 1 pt. MA
I wasn't sure if I should make this a new question so I'll just stay on this thread.
I have been monitoring my pool chemistry almost every day since July 13 2014. Since that time I have added 12 lbs. of baking soda and 6.25 gal. of Muriatic Acid. All of my numbers are good:
FC 6.8
CC 0.0
pH 7.8
TA 90
CH 275
CYA 70
My question has to do with my pH. It is always high. As you can see I am continually adding acid. It just seems like a lot of acid. I am wondering if my pH is just normally high and if there is any thing to worry about with a high pH. My K2006 test kit only goes up to 8 so I am not sure how high my pH actually goes. Is there a different test kit that has a higher pH range? How high is too high? Do some pools naturally have a high pH? This is driving me nuts! Any advice is greatly appreciated. Thank you.
