Closed Thread
Thread: Shotcrete vs Gunite
    DaBomb650 is offline ** No working email address ** DaBomb650 0
    Default Shotcrete vs Gunite
    Any thoughts on which is better?
    We are having a pool put in by a nationwide company. One of the reasons we went with them is that they are using Gunite and not shotcrete.
    From what I have read, the Gunite is stronger.
    Great forum by the way! Lots of great information.
    Downingtown, PA
    Default Re: Shotcrete vs Gunite
    Good luck getting a straight answer... I think this is going to be similar to a vinyl vs plaster discussion :-D I do have to say that my 30 yr old gunite pool looks as good as new with no major problems since install... of course you could probably find someone with a 2 yr old gunite pool with complete failure.
    Outside of Philadelphia, PA
    18' x 40' IG - 22K gallons
    Sylvan Gunite Pool (1979)
    Plaster re-done (1997)
    It does not make any difference wether you use gunite or shotcrete both will do the job. The important part is your pool company or sub good at the method of application. There are bad gunite jobs and bad shotcrete jobs.
    JonnyG is offline Registered+ Thread Analyst JonnyG 0
    I have a shotcrete pool. In all of my research, shotcrete seem to be the best with the only downside being slump. This is where the heavy concrete tends to not stay straight on the walls. The gunite seemed to need more expertise to be applied and could have more problems with having the higher strength of the lareger aggregrate concrete. Based on everything, I choose the shotcrete and I am very happy I did. The slump prblem never happened and the pool looks beautiful. I would worry if the the guy running the gunite gun is learning to do it on your pool or hes an expert. Seems that he could ruin your pool and it may take a few years to find out (or you can have a piece of the pool sent out and tested for hardness). The question is whether you trust the guy they send to your house to mix the gunite on site or the concrete plant that does this all the time. I chose the concrete plant (shotcrete pool).
    My two cents
    John
    JonnyG (Hunterdon, NJ)
    30,000 Gal IG Shotcrete (Carlton Pools)
    SW Generator
    6ft Sheer Descent
    Jandy equipment (60sf DE filter)
    Zodiac Mars booster pump cleaner
    Teledyne Lars 400,00 Btu heater
    BBB believer
    Well, the pool contractor is offering a "lifetime warranty" on the gunite pool structure. They tell me they 1 guy that does their gunite, he has been doing it for 20 years. These make me feel a little better about the whole thing.
    Sanford, FL
    I would go with what the pool builder is most experienced at installing.
    Completed 8/21/06
    Spa with spillway
    250K BTU gas heater (for spa)
    SWCG - Aqua Rite
Closed Thread
  1. Gunite already calcium deposits and small hairline cracks of both plaster and gunite
    By getittogether in forum In-Ground Pool Construction and Repair
    Last Post: 04-10-2011, 01:45 PM
  2. My first Shotcrete pool
    By Waterworks in forum In-Ground Pool Construction and Repair
    Last Post: 05-16-2006, 04:56 PM
  3. Drymix Shotcrete
    By HAYMAN in forum In-Ground Pool Construction and Repair
    Last Post: 05-15-2006, 03:54 AM
  4. shotcrete vs gunite
    By beachbum249 in forum In-Ground Pool Construction and Repair
    Last Post: 04-22-2006, 05:29 PM
  5. ShotCrete vs. Gunite
    By Deal Svengali in forum In-Ground Pool Construction and Repair
    Last Post: 04-03-2006, 03:51 PM
