Watermom
You may have something in the pool that you can't see that your chlorine is working on. This evening, add enough bleach to take your chlorine level up to 15ppm. An hour or two after adding it, test and record your FC and CC readings. Tomorrow morning within an hour or sunrise, test FC and CC again. Report those readings. We are looking to see how much FC you are losing overnight from sundown to sunrise and also if you have a CC reading.
Just to confirm, you do have a K2006 kit and not a K2005, right?
