You have the right idea. You can drain down as much as leaving a foot of water in the shallow end and you should be ok. I would guess you need to do 3x to get close to 50 cya. That is... if each drain equals 25% of your total pool water volume, the first drain will reduce your 130 cya to about 97. The next drain will take it to about 73 and the next to 55. Be sure to run the pump for a couple hours after each refill to mix up the old pool water with the new fresh refill.
You may still find yourself using those 3inch tabs at some point. So keep them handy for when you go on vacation and when you may need to add cya next season. Search the forum for proper storage tips. They will also reduce your pH with use. You reported a 7.2 pH reading correct? The pH test with your FC so high will be artificially higher than actual. To be safe, you may want to retest the pH by diluting it down to a 25% sample. Take a measuring cup and fill 3/4 cup with distiller water and 1/4 cup pool water for a full cup of test sample. Stir and then test the pH. If it reads less than before, your gonna want add some (20 Mule Team) Borax to raise the pH back into proper range.
