Thread: above vs inground chlorinator
    Jun 2014
    News Jersey
    Default above vs inground chlorinator
    Hello All,
    I have an above ground pool that I use an inline chlorinator with (tri-chlor pucks). The cap of the chlorinator now has a crack in it and the company was going to send me a new chlorinator, but they mistakenly sent me an inground inline chlorinator instead. The only difference I can see on the 2 chlorinators is that the inground one hold 9 lbs of pucks and the above ground holds 4.5 pounds. Even the plumbing hookups look the same. Can I use the inground chlorinator on my above ground pool and just use the 4 pounds that I was using before or is there some difference i don't see?
    thanks
    John
    Default Re: above vs inground chlorinator
    Make / model of chlorinator?
    personally, I am a fan of floaters with adjustable vents, that cost about ten bucks, when I want to use tri-chlor tabs.
    Jun 2014
    News Jersey
    I actually don't like them just because my filter is on a timer and when it kicks on, if my solar cover is on, the floating chlorinator doesn't circulate around the pool-in any case, I will continue to use the in line model i have plumbed in
    Midwest
    I have an older Hayward inground in line chlorinator, that I use when I go on vacation. I don't find the adjustment valve very accurate and I only put a few pucks in at a time.
    Quote Originally Posted by Shredhead View Post
    I have an older Hayward inground in line chlorinator . . . I don't find the adjustment valve very accurate
    Bingo! That's one of the two reasons I hate those things. The other is the enormous flow restriction those beasts introduce:
    That product is an interesting example of how even better companies like Hayward will continue to produce a known defective product, as long as it sells. It also illustrates why it's not possible to have a 'best-of-breed' pool equipment set up, if you stick to a single manufacturer!
  1. Chlorinator location
    By pete c in forum Pool Equipment & Operations
    Last Post: 07-13-2013, 10:15 AM
  2. moving a chlorinator
    By mp11735 in forum In-Ground Pool Construction and Repair
    Last Post: 05-28-2011, 09:54 AM
  3. BBB Method and Chlorinator
    By psciotti in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-04-2007, 12:29 PM
  4. automatic chlorinator
    By crackerjack in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-18-2006, 09:40 PM
  5. Pool Ex Chlorinator
    By SteveColby in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-16-2006, 06:04 PM
