Results 1 to 10 of 23
Thread: New Pool Owner
    Jul 2014
    Austintown Ohio
    Default Re: New Pool Owner
    Thanks Watermom! I really hope that pump is ok, it's the best one we could afford at the moment and it's being shipped to us already :-(
    Jul 2014
    Austintown Ohio
    Does anybody have suggestions and links to any adapters I may need?
    I currently have 1 1/4" hoses and the new pump will have 1 1/2" hoses.
    I just edited this post by eblade, and stickied it. I think you'll find it helpful:
    www.poolforum.com/pf2/showthread.php/24529
    BUT . . . I strongly recommend that you go ahead NOW and order Unicel cartridges, and learn to manager your pool as is. The sand filter is not a fix-all. If you haven't looked though the Simple Recipe page, I'd recommend doing so: http://pool9.net/ssr/. You may want to get the Unicel, drain, and restart using the SSR.
    You may also want to consider ADDING the Intex filter, rather than replacing the Pro Series one. Either way, I think you'll see that the conversion is a bit more involved than you imagined. Draining and refilling, following the SSR would allow you to enjoy your pool this year, as you work toward replacing or adding to your existing filtration.
    BigDave's Avatar
    Quote Originally Posted by CMaxim View Post
    Check the box when it comes in, it may come with adapters, I can't really tell from the website.
    Jul 2014
    Austintown Ohio
    Smile Re: New Pool Owner
    Thanks for the replies guys!
    This is actually my 3rd summer owing a pool
    The past 2 summers we had a 18' intex pool with one of those blow up rings at the top.
    We have always had problems keeping the water clear.
    So this year we decided to buy the proseries pool just because it had a skimmer and is much better built.
    I do have some experience with the chemical part of it all, I have always been able to keep the water fairly balanced thats why we ordered the sand filter, I'm tired of the paper filters getting clogged and having to spray them out all the time and always replacing them.
    I will look in the sand filter box when I get home from work today it will be delivered sometime today.
    Is it necessary to use plunger valves at the intake and outtake points?
    I'm keeping the skimmer that came with the pool, my plan is to remove the paper filter and attach the pump on the bottom or the side of the skimmer.
    I'll let you know what parts are included upon inspection of the package!
    Thanks so very much for your help guys'
    Corey
    20' Summer Escapes / Pro Series AG pool
    Jul 2014
    Austintown Ohio
    Nope it did not come with any adapters at all,
    Not even the strainer where the water flows out!
    I thought it would atleast come with the 1 1/2" connectors.
    BigDave's Avatar
    Thanks for the follow up. Sounds like you have some "innovation" ahead of you.
    Get the Unicel cartridges ASAP.
    Please, take pictures of what adapters you find. This is a somewhat murky area without standard solutions, so whatever info you can add to the 'pool' will help.
    Jul 2014
    Austintown Ohio
    Sorry I haven't posted in the past few days!
    I have been very busy at work :-(
    Good news is I figured out how to easily convert my pool.
    This was purchased from my local pool store
    I also purchased a 1 1/2 pool return fitting and screwed the part above to that. (I did have to carefully cut the opening a bit bigger so I could fit it thru the hole)
    On the skimmer I cut the hose that came with our new pump and just used a hose clap to hold it in place!
    No leaks!
    I hope this helps!
  1. New pool owner here
    By mailman in forum Above-Ground Pool Construction & Repair
    Last Post: 08-31-2013, 11:55 PM
  2. New pool owner HELP
    By Schanson76 in forum Dealing with Algae & Slime
    Last Post: 08-21-2012, 04:34 PM
  3. new home owner -- new pool owner -- clear as MUD
    By Andyman33 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 09-06-2011, 07:51 PM
