Cloudy Pool
I have had a pool for more than 20 years and now I am faced with a cloudy pool that is being very slow to clear. I am using a sand filter and new sand did not clear the cloudy pool with any speed at all. I need to be clear in 4 days from now. I decided to change from sand to a zeolite media sold by Leslie Pool Supply. Still it is very cloudy but it has only been running with the zeolite for 16 hours and it is probably too early to judge whether it is clearing up. My operating back pressure is 6.5 psi and has yet to climb any noticeable amount. All help and suggestions will be appreciated.
18' X 36' In Ground pool, 18,000 gallons, skimmer and bottom drain, mixing valve before pump strainer, Hayward 3/4 HP pump, Hayward 250 pound sand filter, 3 returns.
- You may not post replies
- You may not edit your posts
Forum Rules
