Thread: Swirling or stirring - what's the difference
    Tucson, AZ
    Red face Swirling or stirring - what's the difference
    Forgive me for asking such a silly sounding question. But, is there a difference when mixing instructions say to swirl and I stir, or vice versa?
    Tucson, AZ
    In-ground Gunite
    20,000g
    Default Re: Swirling or stirring - what's the difference
    With all the pool tests I've ever used, the goal is just to get it mixed. Maybe if you've got some sort of unusually test that depends on precipitation, it would matter whether you stirred instead of swirling. But I haven't seen anything like that with consumer (or even dealer) level pool testing.
    Ben
    "PoolDoc"
    Ah, but when mixing drinks it's critical to chill the drink evenly without watering it down to much.
    Thus:
    "Shaken, not stirred!"--James Bond
    Tucson, AZ
    Quote Originally Posted by PoolDoc
    Ben
    "PoolDoc"
    Thanks. The only thing I can think of maybe is contamination (from a previous test, etc.) skewing the test in progress. My wife likes to use a little wooden stick to mix, and I prefer the swirl.
    Tucson, AZ
    In-ground Gunite
    20,000g
    laboratory procedure would be to swirl or to use a magnetic stirrer while the titrant is being added. Some pool stores do use magnetic stirrers. It's just faster. If you swirl be sure to do it for 10 to 30 seconds between drops for good mixing. Manual stirring is probably not much faster, magnetic stirrers spin pretty fast and will create a vortex in the liquid similar to a blender.
  1. Difference between AG and IG filters?
    By sunlove in forum Pool Equipment & Operations
    Last Post: 05-15-2012, 01:42 AM
  2. Difference in PPM, which one is correct?
    By cjryan33 in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 04-12-2012, 01:11 PM
  3. Difference in DE filters?
    By cruzmisl in forum Pool Equipment & Operations
    Last Post: 05-12-2007, 12:35 AM
  4. PS234 & HTH 5-way difference...
    By csevel in forum DPD-FAS based testing
    Last Post: 06-09-2006, 11:08 AM
  5. What's the difference between AG and IG heater???
    By The Mermaid in forum Pool Equipment & Operations
    Last Post: 06-02-2006, 07:25 PM
