Thread: How to add muriatic acid
    BullDean Guest
    Default Re: How to add muriatic acid
    Thanks for the response..
    Just added my second dose.... about 12 oz....
    Any idea how much I can add at a time and how long it might take..
    My pool is about 5000 gallons and my pH is currently 8.2
    BTW I noticed you are from Charleston..
    I live near Columbus, OH...
    But I lived my first 18 years in Clarksburg which is about an hour south of Morgantown, WV...
    Thanks again
    How much you're going to have to add and how long it will take depend on your T/A........
    BullDean Guest
    Well I have gotten my PH down to about 7.2 / 7.4
    Took 2-3 days and a gallon of acid...
    Now that I have the ph this low.. Is it ok to keep adding the muriatic acid when needed.. Or should I switch to a pH decreaser...
    Muriatic acid IS ph decreaser. The other stuff (dry acid) is sodium bisulfate and it creates sulfuric acid when dissolved in water. It is not as effective as muriatic acid and costs more. Doesn't really matter which one you use but most of us on the forum use muriatic.
    As long as you don't pour either one into the skimmer it won't hurt your cartridge filter.
