Results 1 to 10 of 72
Thread: Cannot raise CYA
    QiingGuy is offline Registered+ Thread Analyst QiingGuy 0
    Jun 2014
    Las Vegas
    Default Cannot raise CYA
    Intex 16 x48" approx 4,800 gallons, Intex SWG
    For the life if me I cannot raise my CYA over 30. I've used approximately 2 lbs of Leslie's conditioner and that got me to 30. Then approximately 3 lbs of HTH Stabilizer & Conditioner (maybe .3 lbs still in sock) and I'm still sitting at 30. I just put the remaining 1 lb of HTH in a warm bucket of water to dissolve and I'll throw in the pool tonight to see if that helps. Any suggestions? I'm trying to get to 80 ppm.
    I'm currently running my SWG 2 hours per day AND adding 1 cup of bleach to the pool daily.
    Here are my other numbers:
    FAC - 2
    TAC - 2
    Salt - 3,100
    TA - 110
    pH - 7.5
    Copper - 0 (I disconnected the copper connection on my SWG)
    Iron - 0
    Phho - 100
    Default Re: Cannot raise CYA
    How long ago did you add all of this stuff? I think you are likely going to find out that your overshot your target by quite a bit. Adding 5 lbs. of CYA to a 4800 gallon pool should add about 135ppm!! Don't add that last pound!!
    What is the source of your fill water? You might want consider draining almost half of the water and refilling. That would put you at about the target you wanted.
    Jun 2014
    Las Vegas
    @Watermom - I HAVE NOT ADDED TODAY'S APPLICATION YET and will hold off until I receive further expert advice.
    I added the original 2 lbs on June 19, 2014. The follow-up HTC application was done on July 5, 2014. ADDITIONAL INFORMATION: Either a couple of days prior to or after I did the HTC application I needed to add a cup of Klean Strip Green Muriatic acid to lower my pH. Don't know if this could effect my CYA level or not but thought I'd throw it out there just to be safe.
    The original application was dissolved in a 5 gallon bucket and added to the pool (this application got me to 30). Second application was done in sock hanging off the side near in-let or out-let forget terminology (water coming into pool). I have approximately .3 lbs left in sock. It appears the second application has not raised CYA at all.
    Source is from hose/city water. Why drain, I'm 50 ppm from where I need to be. Confused . . .
    EDIT: One last thing, I've done three separate tests. One my own, and two at separate Leslie's locations.
    2 lbs should have added about 55ppm. 3 more lbs. should have added an additional 80ppm.
    But......... hold on. Those numbers were based on a volume of 4800 that you reported. I just now calculated your volume. I don't think you have 4800 gallons. I think you have more like 5600 gallons.
    So, in 5600 gallons, 5 lbs. of stabilizer should have added 115ppm of CYA.
    I don't know why you're not getting a reading. What kit are you using to test with?
    Jun 2014
    Las Vegas
    I tested with a Taylor K-2006, then I had two separate Leslie's stores test.
    Have you had any algae outbreaks since you added the CYA?
    Jun 2014
    Quote Originally Posted by QiingGuy View Post
    Don't know if this is part of your issue, but I wouldn't use the brand "Klean Strip Green Muriatic acid". There's no amount of concentration labeled and it has unknown / unwanted additives to make it "safer" (a.k.a. not safe for pools).
    http://www.homedepot.com/p/Klean-Str...5006/202690263
    19.5k gal, 16x32 vinyl liner, sand filter, 1hp single speed pump, K-2006 test kit. PF=6
    Jun 2014
    Las Vegas
    Yep, that's what I used 1 cup of it. Think it could have something in it that's killing my CYA? It's all Walmart carried so I didn't think there was another choice.
    Jun 2014
    It's unlikely that small amount would effect your CYA. But who knows what else are the "safer" additives and what they'll do to your pool and / or yourself. Only buy chems that have the amount of concentration labeled.
    Try Lowes. Good luck.
