Results 1 to 10 of 72
Thread: Cannot raise CYA
    QiingGuy is offline Registered+ Thread Analyst QiingGuy 0
    Jun 2014
    Las Vegas
    Default Re: Cannot raise CYA
    Sorry, cc of .02.
    I have not shocked. Someone suggested I test with my kit vs. the pool store test my wife's been doing prior to shocking. Now I'm questioning the values I've been getting from the pool store.
    So do I hold off on the shock?
    Intex Ultra 16' x 48 5,061 gallons, Intex SWG, Intex 1,500 gph pump K2006, Unicel, city water
    Jun 2014
    I could of been more stern but this a nice forum. Other forums I would of busted on you
    Those pool store results you posted didn't jive with you having a clear pool. CYA pool store (a.k.a. fool store) testing isn't worth the printout they gave you.
    Testing is like your pool GPS. It works because it first figures out where you are and then tells how to get where you wanna be. In other words, you'll never find you way to NYC from Las Vegas if your GPS tells you you're in Madrid. Those pool store results place you somewhere east of the Nile River and nowhere near the Colorado River. Get it ?
    19.5k gal, 16x32 vinyl liner, sand filter, 1hp single speed pump, K-2006 test kit. PF=6
    Quote Originally Posted by Big Splash View Post
    Just to be fair . . . from what I see here, I'd guess that at least 1 pool store in 50 provides accurate testing and generally reliable advice. It might even be 1 store in 20.
    So, not all pool stores are bad. The problem is, the only way to know whether you can trust yours, is to learn enough so you don't need them much, even if they ARE trustworthy!
    Jun 2014
    Fair enough
    Jun 2014
    Las Vegas
    So do I shock or not? Not sure what my next step is, if there's a next step at all.
    Jun 2014
    If your pool is clear, the CC is at or very near zero, and you're not loosing FC at a rate that is more than what you normally would per day, then you don't need to shock.
    Testing yourself is the best way to be sure. Check out the Taylor K2006 Videos on YouTube in this thread;
    http://www.poolforum.com/pf2/showthr...eos-on-YouTube
    Good luck
    Jun 2014
    Las Vegas
    SHOCKED!
    Came home today and pool water was cloudy with a green tint to it so I added 5.531 quarts of bleach that should raise me to just over 22 ppm. Not sure what's going on as I was crystal clear two days ago. We have had a couple of storms roll through, nothing major, a little rain but lots of dust. Property behind me is about 4 acres of desert so when a wind storm comes up it blows dust everywhere.
    Understand I need to keep shock level up until my CC is at zero and I'm losing no more than 1 ppm chlorine per evening right. What's odd is this is where I was, or where I thought I was. Figured I'd shock just to be safe.
    So after shocking how long should one wait until they get in the pool? Thanks in advance.
    May 2014
    Plano, TX
    Ok, if I understand, your CYA is around 80, and your chlorine is 20? If that's true then the pH test is invalid unless you diluted (50/50) the pool water with DISTILLED water. Chlorine levels above 5ppm (or 10 with the Taylor kit) cause invalid results. If you have cloudy water and the Intex cartridge filter, you need to run the pump 24/7 and you still may be a week or two from clear water. [EDIT] The manual recommendations are for "IDEAL" conditions, and that is not where it seems you are. [END EDIT] I'd turn the SWCG off and use bleach to chlorinate TO SHOCK LEVEL (20 to 25ppm for you) until these 3 things are true,
    1. There is less than 1ppm FREE chlorine loss over night
    2. There is less than .5ppm COMBINED chlorine at sunrise
    3. There is no sign of live algae
    Doing this will help extend the life of the SWCG, and needs to be done if the SWCG is on or off. It is lots easier to tell what's going on without the SWCG because it adds an indefinite amount of chlorine.
    With your CYA level, you're looking at a MINIMUM free chlorine level of 8ppm. Maybe shoot for starting with 12ppm and see if that is still 8 at sundown.
    That being said, IF there is no sign of LIVE algae, and you can see the bottom of the pool, and your chlorine level is between 8 and 16, it is safe to swim. Wear old suits. Stirring up the water will help get the dead algae to the filter. Be sure to read
    http://pool9.net/cartridge-clean/
    ALSO, I'm pretty sure that all Intex SWCGs have a copper ionizer. Copper kills algae fairly well, bacteria - not so much. Copper can stain pools and turn light hair green (it's not chlorine that does that). If you keep enough chlorine to kill the bacteria, that's usually enough to kill algae. You might want to see if you can SAFELY disconnect the copper ionizer.
    Good luck!
    Pappy
    Jun 2014
    Las Vegas
    Thought I'd update.
    Came home from my business trip and pool looked beautiful, crystal clear. FC was about 8 and less than .5 ppm Combined. Combined has consistently hovered around .5. Perfect right . . . not quite.
    I'm running my pump 6 hours a night and SWG 4 hours and my FC still drops down as low as 2ppm. I'm starting to think there's an issue with my SWG and it cannot keep-up with the chlorine loss. I'm not losing a lot of chlorine, probably less than 1ppm each night so I'm adding bleach about every three days, however, I was hoping with my SWG I'd be at the point of it maintaining. Don't mind adding bleach but what good is the SWG then . . .
    Other than the pool being a bit dirty from storms this past week numbers and water look awesome! Thanks again to everyone who helped this newbie out. Will be much easier when we get our in-ground in now.
  1. Should I raise my cya?
    By gmh757 in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-25-2014, 11:18 AM
  2. Can't Raise my CYA
    By cooper in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-01-2012, 08:49 PM
  3. Cannot seem to raise Ph
    By D_Case in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 03-19-2012, 01:45 PM
  4. No CYA - How to raise it?
    By mortimay in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-03-2011, 06:33 PM
