Results 1 to 10 of 47
Thread: Solar Heater, Brand, Cost and Hookup
    BigDave's Avatar
    Default Re: Solar Heater, Brand, Cost and Hookup
    Sounds like it should work. One caution, the pump may not ba able to generate enough head to get the water to the roof. Can you rig a garden hose to the ouput of the S.E. pump? Get water pumping through the hose then lift the open end to above the mount height of the panels.
    May 2014
    Lynbrook, NY
    BigDave
    Your always here to the rescue
    I can mount the the pump on the roof,
    Please look at the diagram and advise if this how you like me to hook it up, as far as the garden hose are you referring to supply my own water flow to the pump, then the diagram wouldnt work
    BigDave's Avatar
    It's far more likely that the pump would be able to push the water up than pull it up. I wouldn't even try to put the pump up high.
    I didn't mean that the garden hose should be used for the solar panels but to test if the pump can push the water up to the roof.
    Perhaps both pumps in series would help. Install a T after the filter with one leg going to the pump for the solar loop and the other back to the pool.
    Install a valve between the T and the pool to shunt all the water to the solar pump when it's closed.
    Install another T between the valve and the pool and use this to return the heated water to the pool.
    Also your picture shows water entering at the top of the panel, it should enter at the bottom and leave the top so as to push the air out of the panel as it fills.
    Consider how to winterize the panel as well. Are you going to remove it? If not, it'll have to be drained and dried and so will the piping.
    If you mount it to the roof with screws, put in the screw, then remove it and fill the hole with roof sealant, then put it back in. Maybe even cover the head of the screw with sealant unless you're going to remove the panel. If youre going to remove the panel, you'll need to leave the screws in so the roof won't leak.
    May 2014
    Lynbrook, NY
    Big Dave,
    Makes sense to run the S.E. Pump in series after the intex pump and before the SWCG. The T fitting make a lot of sense. As far as mounting the solar panel, I will probably stick to draining all the lines via adjustable pressure compressor like sprinkler lines.
    Any company or brand you might recommend for a solar kit so many bad reviews or just not enough reviews? I would love an electric heater, but i do not know of any companies that offer such a heater for such a small pool. Bestway, Intex make electric heaters but only available in Europe.
    May 2014
    Lynbrook, NY
    Big Dave
    First i will try to run the pump separate without the t fitting according to the garden hose method, the S.E. Pump is a 1000 GPH pump.
    BigDave's Avatar
    It sounds like we may still be misunderstanding each other - sorry. I only discussed the garden hose as a means to test whether or not the pump would be able to push water all the way up to the roof.
    I'd plumb the entire solar loop after the SWCG. You may also face a challenge with the SWCG, it probably requires a minimum flow or pressure to work.
    May 2014
    Lynbrook, NY
    BigDave
    No need to apologize, you have been such a great help and informational teacher. I have been looking to scrap the idea of a solar heater for my pool and looking into an electric heater, cost will be more but i think it will be more effective. I been searching for a heater, from reading most information i see i will need probably a 5.5kw heater for about a 3600 gallon pool. I came across this little heater which is pretty unique http://www.waveheater.com/. I have read also spa heater are no safe or recommend for a pool.
    Please Please Please give me some light on electric heater, for my size pool.
  1. Is Solar still cost efficient in Ontario?
    By BigSplash in forum Pool Equipment & Operations
    Last Post: 06-08-2011, 09:27 PM
  2. Which brand of solar panels used by professionals and where to get them?
    By 105ex in forum Pool Equipment & Operations
    Last Post: 07-28-2008, 07:12 PM
  3. Anyway to figure out cost per hr of a natural gas heater?
    By cruzmisl in forum Pool Equipment & Operations
    Last Post: 06-25-2006, 05:30 PM
  4. Solar Reel with SS steel bearings low cost?
    By Aranon in forum Above-Ground Pool Construction & Repair
    Last Post: 06-16-2006, 11:14 PM
  5. brand advice & average cost for an installed generator system?
    By mattmcarroll in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 04-22-2006, 02:25 PM
