Results 1 to 10 of 47
Thread: Solar Heater, Brand, Cost and Hookup
    Jul 2014
    Christmas, FL
    Default Re: Solar Heater, Brand, Cost and Hookup
    I looked at that thing... $500!!?!?!?! The pool didn't cost that much!!! No way... and it's 220-240V!!! WHAT!?
    IMHO... I smell SPAM... Just sayin'...
    5.2k gal 16' x 48" Summer Escapes AG, Intex 2650 Sand Filter. PF=23
    May 2014
    Lynbrook, NY
    Watermom
    LMAO
    Quote Originally Posted by eblade21 View Post
    Watermom
    LMAO
    Why? That really is the name of it.
    May 2014
    Lynbrook, NY
    Sorry about that wrong thread
    No problem.
    Jul 2014
    Christmas, FL
    I still say... SPAM....
    May 2014
    Lynbrook, NY
    I meant to send (LMAO) to Waldog.
    Why is my name come up that i cant be trusted?
    May 2014
    Lynbrook, NY
    Big Dave
    Would you recommend this setup?
    BigDave's Avatar
    I'm suggesting more like the following:
    pool
    New Pump
    New Filter
    SWCG
    Tee-->To Solar Loop (below)
    Valve
    Tee<--From Solar Loop
    Pool
    Solar Loop:
    Tee (To)
    Solar Loop Pump (ground level)
    Panels on roof
    Tee (From)
    I also suggest you to test the pump or pump combo to be sure you can pump water up to the roof.
    May 2014
    Lynbrook, NY
    Cool Re: Solar Heater, Brand, Cost and Hookup
    Hi all
    I need some help of course if no one minds here is where I am currently I just purchased one of those dome panels and bypass kit, before my decision I decided to monitor my back yard and see where can lay this on the floor where I can receive all the sun rays thru out the day, I sat outside all day from sunrise to sunset. I luckily found a perfect location right next to my pool but completely opposite of my sand pump. I like to stay with my screw type connections of 1.5 inch hoses. I also purchased a 16 mil clear solar cover to assist in maintaing the heat in.
    I like to connect the panel in this manner:
    Pool
    Sand pump
    Bypass valve
    Solar in Tee
    Solar out SWCG
    Pool
    I'll explain from the pool to my sand filter pump I will connect the bypass valve one leg will go to the solar panel feed one leg will go to another tee from that tee one leg will go to the solar out supply and one leg to the SWCG from there returned to the pool.
    1.Do you feel this will work?
    2.Do you feel using one panel do I need a bypass valve? I like the idea because in the early afternoon I can run my pump just filtering the water and the solar heater, and at night I can run my pump with the SWCG without the solar heater?
    3.If you scroll to the beginning of the thread you see my current pump specs, will this be enough to travel around the other side of the pool figure about an additional 10 ft of hose?
    4.If I just use the bypass valve after the filter, can I use just a sprinkler set up coming out of the solar dome? Which I wouldn't have to run a hose back to the return just right out of the dome to a PVC sprinkler?
    I also thought of buying a separate pump like one of those intex 637r just to run the solar dome heater? Your thoughts.
    Everyone here has made my pool breathtaking and beside a light all that left is heat, I like to extend to at least to the end of September that why I decided on a pool solar heater.
    I am really sorry for all the questions, sorry for being all over the place thank you for all your help
    Eddie
    Eddie
    Summer Escapes 14' Pro-Series 4047 gallons, Intex 12 inch sand pump, Intex SWCG, Intex 2500 GPH Filter Pump, surrounded by Vinyl Works Fence using a Taylor K-2006C and Taylor K-1766, Sungrabber 4 x 12 feet Solar Collector, Hayward Aqua Solar GL-235, 12 mil Clear Solar Blanket
  1. Is Solar still cost efficient in Ontario?
    By BigSplash in forum Pool Equipment & Operations
    Last Post: 06-08-2011, 09:27 PM
  2. Which brand of solar panels used by professionals and where to get them?
    By 105ex in forum Pool Equipment & Operations
    Last Post: 07-28-2008, 07:12 PM
  3. Anyway to figure out cost per hr of a natural gas heater?
    By cruzmisl in forum Pool Equipment & Operations
    Last Post: 06-25-2006, 05:30 PM
  4. Solar Reel with SS steel bearings low cost?
    By Aranon in forum Above-Ground Pool Construction & Repair
    Last Post: 06-16-2006, 11:14 PM
  5. brand advice & average cost for an installed generator system?
    By mattmcarroll in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 04-22-2006, 02:25 PM
